Speakers rattle controls in door.
Blubble
I have an 03 Limited with the 10 speaker system. When I play certain songs with a lot of bass, I get really bad vibrations from the front door panels. The worst rattle seems to come from the power window and door lock switches vibrating. While the noise is irritating, I am more concerned with damaging the switches in the long term.
I have thought about using Dynamat or something similar. However, it seems that this will help reduce overall noise, but may not work on a problem spot like the switches.
Can anyone recommend a better solution or something that can be used in combination with Dynamat to resolve this problem?
i took the door panel off recently and found that the lock and window switches just pops in and out of the panel. perhaps you could try and pad their connection a litte with some thin weatherstripping?
DanielShawSZ
