checked when you rotate your wheels/tires
Is it easy for the adapters to come loose when rotating tires?
Correct, simply inspect each spacer. I normally set my tq wrench 5lbs less than the original tq spec. This gives me peace of mind they are not loose, and does not break the loctite bond.
