Spidertrax studs not fully pressed in
jreiter
I recently installed Spidertrax wheel spacers, and I found that many of the lugs felt soft while torquing them, like they were stretching or pulling. I went to a shop and had them check all the studs in the spacers. Turns out that many of the studs had not been fully pressed in by Spidertrax. The shop pressed all the studs in properly, and now the lugs feel very solid and can be torqued properly
So consider this a heads up: If any of you have Spidertrax wheel spacers, you should check that all of the studs are fully pressed in before installing them!
thanks for the heads up! i will be installing my spacers on Friday along with my rims/tires.:driving:
