supraholic
Hi all,
I installed an LED light bar today as prescribed in this thread: http://www.toyota-4runner.org/4th-gen-t4rs/139354-stealth-led-light-bar-install.html . I used the same parts and followed the same basic principle. However, the Sport Edition roof rack is quite different than the SR5/Limited rack.
Pry off the cap/cover gently...I grabbed the top with both hands and worked side-to-side while pulling up and it came off. You can see it's held by just two plastic posts--no clips:
Need to remove two torx bolts and one torx screw on the inside of the rail:
Now the mount can be removed:
Here I show where I had to trim some spines in the mount to allow room for the plug and wires to be hidden. I removed the minimum to make sure I didn't compromise it's strength:
All trimmed and ready to put back together:
Use silicone or some type of sealant around the bolt holes before putting the rack mount back on:
Another key difference with the Sport Edition roof rack is that the channel in the side rails is narrower than in the SR5/Limited rack. This means that you have to remove the corner mounts anyway to slide the light bar brackets (w/draw bolts) into place. Everything slid into place and the corner mounts bolted down:
The cap/cover fits great and hides the plug and wires perfectly:
A few more shots of the setup:
I still need to finish the wiring in the cabin but will post some night pics once it's done...
