The Sport has XREAS standard, whereas it's optional on the Limited. The XREAS is more comfortable than the standard suspension, so I don't see that being a reason. It is possible that the XREAS has failed, it is quite common unfortunately. If you look at the shocks, you will see a line (hydraulic) connected to them. Check the shocks to see if they are damp, it's possible they are leaking and causing the rough ride. My second thought is maybe it's the tires. What size and load range? Tires with a heavy load range ride worse (generally). So, if he has the sandard P rated tires and you have LT's or something heavier duty, that's also a possible reason. Then again, it could be a combination. How many miles on your sport?
