Curt Sauve
Has anyone installed a Sprint Booster on their 5th gen. yet?
SprintBooster Power Converter - www.SprintBoosterSales.com
So what did you use for a heat shield? Is it worth the time and expense?So the correct one came today, or at least one that fits the 2010 and up 4Runner. It is Sprint Booster part number SBTO1002, which is for the 2006 to 2010 RAV4.
I noticed that there is better throttle response as well as not having to mash the throttle to get more power out of the car.
Installation note. Because Toyota in their infinite wisdom decided to route the heater core pipe right above the throttle control module, the sprinter booster winds up placing the OE factory throttle wiring and connectors up against the pipe. Therefore you would have to find some heat shielding so the OE factory harness and connector doesn't melt.
Is the unit that they sent plug and play or did you have to modify it with a heat shield as in previous posts?Have one on my 2011 limited- just put in on this week. This is what the car should have been in terms of throttle control from the factory. The green setting (lowest) is best. The car is no faster, just reacts differently to peddle. I know going up hills i can make the car react the same with more throttle but it was just not like any other car i have driven how dead this peddle was. It feels much better. I got it for $299. It is pricey but its pretty cool and i like it and that is what counts.
