I don't think a timing belt can squeak as it is ribbed crosswise and if it slips at all you will go out of time and a squeak would be the least of the problems. Accessory belts (A/C, P/S, Alt.) do squeak and can be a) old b) loose or c) both. Step 1: see if they are tight. If not, tighten. You can take a spray bottle (Windex type) with just water and spray on the pulleys one by one. If noise goes away briefly, that's where your problem is.
If just tightening doesn't do it, then it's time to pull the belts and check each component and idler for problems. If the belts are quite old, they will squeak even if tight. Mine began to squeak at about 115K and all 3 got changed at 120K when I did my TB/WP. Problem solved.
