Squeeky A arm
Brian1973
Guess they are called control arms? Been on some rough 4WD roads lately, getting alot of squeekin up front... All i currently have is pb blaster. Sprayed from engine compartment on the joints and it went away for a while... Back again... Is this an issue? Or shall i just get some WD40 and try that?
Also, tried to do a search from mobile device and the pop up search box would appear, but when i went to put cursor in it by tapping in the search box, the keyboard would flash up for a split second, and then disappear with the search box :-( ideas? :-(
Honestly, I believe...based on that description, it could be a number of things squeaking. Though if it is your arm, I would look into the condition of the bushings. They may need to be replaced.
Hope can make it back home 3000 miles... It's the bushings then... That's probably more than a Saturday job? Will spray w some wd40 and hope they shut-up for a while...
