Stabilizer links
Rsina89
Are 2nd gen stabilizer end links required for a 2.5 lift ? It’s for a 2wd . Was wondering if it’ll dramatically increase the ride quality or are the stock ones just fine? Will be for my daily driving commute to work! Thanks for the input !
You'll want the longer links after a lift is installed. Getting your sway bar back to it's intended position will improve the suspension, and suspension travel. You'll want your rear sway bar parallel to the lower control arms if you can.
The 2nd Gen link will give you the added length, but no added strength. There are aftermarket options that'll give you both length, adjustability, and strength.
Mike
johnnya
