Casper
Guys
Just had the Stoptech Stainless Steel Brake lines installed and alli can say is WOW...it sure wasnt a real cheap experiment but i love how the brakes feel now. Imagine making the pedal harder but at the same time less effort (travel) is required to make the brakes work. Im still adjusting but its like this, for those with the Sport brakes, imagine the normal set point of effort that you would use for brakes well that point is just now off the first 1/4" of brake travel. For the entire ride home, i hadn't yet adjusted my braking reaction and when i would attempt to use the same effort with the brakes as before, I would literally get nose dive from the truck slowing so fast. Its great, its just like both of my past BMW's with their upgraded brake systems.
The total for the parts was 200, and the install is actually alot more intensive that once originally planned and hence the original estimate for install ($100) almost tripled (275) but that is due to my service place never doing it before. Those in areas where SS brakelines and brake flushes are done more often should see a reduction in the install pricing.
I was unable to go back to the truck for pictures while thei install was going on for insurance purposes (so they say) but i did take some pictures of the Fluid and the lines that I will post up soon.
As a last note, even the tech that installed the lines made mention to my service advisor that the brakes were much more effective and the braking force that much higher after his road test in the truck.
