shawnstcyr
Well guys, I had the unpleasant experience of changing the starter on my truck today. Thought I'd share some tips to make it easier for you.
Tools needed:
3/8 drive ratchet
12 to 16" extension
10, 13, and 14 mm sockets
12 mm wrench
As always, disconnecting the battery is step one.
Step 2:
remove the 12 mm bolt holding the transmission dipstick tube to the head and remove tube.
Step 3:
remove the 14 mm drain plug from the trans. pan and drain fluid.
step 4:
using a 1/4 drive and extension, remove the 10mm bolts and drop the transmission pan
Step 5:
remove the black plug going to the starter solenoid and remove the battery cable from the starter (13mm)
Step 6:
using the long extension with a universal joint and 14 mm socket, remove starter bolts
Step 7: once the starter is loose, take the 12 mm wrench and remove the power steering line from the rack and pinion. The will allow room for the starter to be removed.
Installation: reverse steps.
I recommend changing out the transmission filter whille you have the pan off. I tried sEveral different methods of removing the starter and this one was the easiest. The Haynes manual says you can remove the starter through the wheel well, this is not true! GOOD LUCK!
Tools needed:
3/8 drive ratchet
12 to 16" extension
12 mm wrench
Step 2:
Step 3:
step 4:
Step 5:
Step 6:
