It has 97K miles. Perfect shape in and out and no issues. The Toyata dealer I bought it from only had records from Oct (when they got it) and when I bought it. Some of the things I see the fixed were:
Antenna mast
New battery
Passenger rear axle seal
Valve gover gasket
I was going to do the front diff, rear diff and xfer case fluids. Was quaoted 225 for all of them. Then I wondered if the rear would have all new fluid from the axle shaft seal? Would that have been totally drained for that fix?
Next I will want to do the coolant and a tune up. Like I said, its all fine and fluids look good but I just like to know for sure when its been done. No idea about timing belt but that will be the last thing I have done.
Antenna mast
New battery
Valve gover gasket
