Steering Rack Guide Questions
LodeRunner
After reading all the nightmare threads about LBJs, I finally decided to replace mine with 199k on the truck. I figured while I was doing those I should replace the OTRs at the same time (whole other story; still can't get the lock nut loose...), and also do the steering rack guide to firm things up a bit.
First question: I ordered the steering rack guide parts from Camelback Toyota, and what I received appears to be the old style guide with the rolling bearing, not the newer style that is solid as described in the replacement thread that I saw. I assumed based on what I've read the old style had stopped being made... Should I return what I received and get the new style?
Second question: What's the best way to remove the old guide once the cap and spring are removed? The replacement thread shows that a parts tray magnet was sufficient to pull it out, but that did not work for me. I'm wondering if I just need to buy a really strong magnet to grab it, or if there's some other trick. Advice?
Thanks in advance!
Another search answered part of my question here. Now wondering like the OP on that post if I should get the new design or just live with the old... Any insight is appreciated.
Tx470
