jreask
Member
I now have a 2008 SR5 178K miles. Decided to try 5100’s front and back. The rears went on fine. I set the front clips at the second notch from the top (1.75”). I did the front using the no spring compressor method. The left side LCA was loosened and dropped down just fine. I was able to get my match marks pretty close but not exactly where I marked them. The right side LCA was loosened but wouldn’t drop down, it kept springing back up when I pushed it down. I ended up using a spring compressor to assemble the right shock. It went in ok. I also changed out the right CV due to a leaking boot. When I took the truck for a test drive the steering wheel is off center to the right. The truck seemed to drive straight. I assume that the alignment is so far off that the steering wheel is off center? Anyone have any ideas ?
Thanks for your help.
JR
JR
