Stereo Dimmer Problem
Harrison
So here's a weird one for you guys, and I have been stumped on it.
I took my 02 SR5 for a bunch of PM and when I got it back I noticed something unusual.
My stereo (which is an aftermarket Alpine CDA-9885) now dims regardless of whether or not the lights are turned on, but this behavior only happens in drive.
For example, headlights off, car in park - stereo is in un-dimmed "day" mode. Headlights off, car in drive - stereo is in dimmed "night" mode. Headlights on, any gear selected, radio is dim. I want to chock this up to a stereo problem since the stealth mode (you push a button and all lights shut off) no longer works on it, but how would I explain why it's receiving a dimmer signal when the vehicle is in drive, regardless of if the headlights are on or off? Is the voltage stepped at all? Or is this controlled by a relay that had failed?
I am concerned this may be a hint of future electrical problems, but that is mostly because I used to have a Land Rover Disco I that had so many electrical problems that it got to the point where the service center said that if I had pressed the cruise control a couple more times, my passenger air bag might deploy.
Does the dash board lights dim when the radio dims? If not then them problem must be with the installation of the radio.
Alpines have a dimmer signal wire (orange on all the Alpines I have done) which is connected to some point on the lighting circuit, usually the parking lights. When that wire gets 12v+, the display dims.
How that translates to your issue I have no clue. Exactly what PM did they do? Can you follow the orange wire out of the HU? Some Alpines have a setting in the setup menu to disable dimming, if that helps.
Fear not, British auto electrical wiring is as bad as their dentistry or their cooking. I find Toyota electrics to be VERY reliable.
CUT THE ORANGE CABLE Bro....
I have had 3 Alpine head units. They all work fine with the illumination cable disconnected. The Alpine will default to 100% brightness which works fine for me.
I doubt it is an indicator of electrical problems but if you had ran a new (+) and (-) power cable as instructed by the Alpine manual then you wouldn't have to worry about the electric power in your dash because the Alpine would be properly powered via a 10 or 12 G wire directly connected to the battery. With a fuse of course ..
erinobr2000
