sticker removal help
Mason Fresh
so i'm trying to remove a stupidly placed sticker on the back window and the whole heat it up thing isn't working... i read a thread on here about using WD40 - anyone have any other suggestions? advice?
thanks!
Is it on the inside or outside??
On the outside just use dishsoap and water combo with a brand new razor blade.
On the inside you have to use a chemical not a razor blade due to the rear defroster!!
outside!
the razor blade is sort of working, but its still being a b****.
You have to use something that will dissolve the adhesive, ....., I always use either lighter fluid or just plain gasoline. Be sure you are not smoking BTW, ....., LOL, I know you don't smoke Mason, but had to throw that in.
:bigok: i'm a good boy!
i finally got it all off with a razor blade and lighter fluid!
now it's time for an orange t4r.org sticker to match my sunset license plate.. WOO!!
when you use a razor, bend it like beckham in the middle with your fingers against the glass and shave off the sticker bit by bit. You'll notice how it picks it off without residue. (Hope that made sense)
