Still no solution for 4R towing mirrors
zonzin
Member
I'm getting real tired of strap-on / clamp-on towing mirrors and their associated issues. I would really like a direct mount solution that is readily available for Tacos, Tundras, Sequoia and most US trucks. Why no one does a 4Runner mirror escapes me.
Here is an after market for a Taco: Tundra after market Mirror
And here is the factory version: Tundra Towing Mirror
Another Taco version: Tacoma Towing Mirror
Any way to adapt to a 4R?
There is a well known mod to *I think* RAV4 mirrors to add integral BSM on 14+ 4runners, please search as it's not far (Maybe someone can link?)
I have the 10 4runner and I bought these or very like these since I didn't directly check my Amazon order history: https://www.amazon.com/dp/B00PJWE9DI/ref=sspa_mw_detail_5?psc=1
Spot mirrors for towing
Hi Zonzin,
Only the Toyota Tundra mirror looks like an improvement over the stock 4Runner mirror. The mirror is bigger in area than the T4R mirror and it has a wide angle viewer across the bottom. The other two seem to be the same size and distance from the door as the T4R stock mirror.
I put round spot mirrors on both my side mirrors. I have a 3" mirror on the driver's side and a 3 1/4" or 3 1/2" (I forget which) spot on the passenger side. These work as well as the Rav4 conversion everyone raves about and it costs a lot less. The round spot mirrors are all less than $10 on Amazon and they go on in a New York minute.
BTW, I finished my Baxter Performance remote oil filter installation. The remote location was a lot of work and the hoses are a vulnerable link in the system. If a hose leaks, you're stuck until you can get it to a shop or home. You were right. The spin on filter under the engine is the easy secure way to have a disposable filter.
I think I forgot to say it's much nicer towing my boat with the long style blind spot mirrors (BSM) that I linked too. I can see 3 lanes on each side with them and they take away a good bit of stress while I'm towing.
YMMV. Buy the taco kit and try it? Then sell it on TW (tacomaworld) if you can't get it to work right.
Hi Zonzin,
I put round spot mirrors on both my side mirrors. I have a 3" mirror on the driver's side and a 3 1/4" or 3 1/2" (I forget which) spot on the passenger side. ....
BTW, I finished my Baxter Performance remote oil filter installation. The remote location was a lot of work and the hoses are a vulnerable link in the system. ..You were right. The spin on filter under the engine is the easy secure way to have a disposable filter.
Yep,, have the 3" BSM,, don't give me what I want to see around the trailer.
The strap on mirrors do but the straps fail and mirror goes boom,, happened a couple of times already.
Yep,, loving the spin-on mod,,so much easier on oil changes.
Can someone comment on this, I'm planning on getting a 7' wide cargo trailer to pull behind my 2003 4R, do I need extension side mirrors for this width of trailer. Thanks.
