scslite said:I was wondering if anybody knows how much the stock alternator can handle as far as installing aftermarket amps for the sound system?
Mine is a 2005 Limited V8. And please don't say just use a cap.
TIA!
Clemsonfan15 said:It's not the number of amps you run, it's the wattage.
I'm glad you don't want a cap because they don't work.
The stock alt for the v6 is 120 amps I think so yours is probably the same or just a little higher.
I would say you could run somewhere around 2,000 RMS. You should probably do the big 3 also.
What amps are you thinking about running?
Clemsonfan15 said:Very true Mike. The only thing I can comment on is that at normal listening volumes you won't be drawing that many amps.
MikesToy said:what's the big 3?![]()
