Stock brake caliper replacement, no tundra upgrade
Dune4Runner
I considered the Tundra upgrade but doent want to deal with a spare not fitting. Plus the kits i found have the red calipers and slotted rotors, which is not what I want. Are the Duralast remans from Autozone fine? I assume these are OEM calipers that have been rebuilt with non oem parts? Any issues with these?
Or, Id be open to a replacement kit, which includes pads, and new rotors too. Thanks
get the napa brand eclipse i believe it is. i have tundra brakes and my calipers are black, napa eclipse. rotors and pads are OE. just changed mine yesterday after 5 years.
IS the napa eclipse that much better? The black finish looks good but Im fine without it...seems to be about $30 more per caliper than the Napa
The non coated calipers will rust within a week.
My naps eclipse calipers are sticking within a year. No longer even braking and pad wear is uneven. Napa does not keep your name in the system so always save receipts.
My next calipers will be used oem.
I did the 199mm upgrade so everything still fits, plus you don't have to deal with warped rotors. Just an FYI, it's totally worth it IMO.
