I believe the one on the left is for an optional CD changer (can also be used for iPod adaptors, etc)
i guess pre-99 came with a single DIN radio?
But my 98 has a double-din headunt too so it must be like no cassette or no single cd player or something
I think the white connector goes to a factory amplifier. Notice the unit does not have any cooling fins or chunk of iron for power dissipation.
Check this one on ebay Toyota 4runner premium stereo cassette w/external amp:eBay Motors (item 160387709446 end time Dec-22-09 23:50:42 PST)
OP better hope you are wrong, because the premium HU is useless without the matching power amp. I know the car harness plug is different from the amp input plug, because lots of people have tried plugging aftermarket adapters into the factory amp and been frustrated. The white jack on the OP's photo looks the same as the output jack on the power amp, and both should mate to the car harness. Your point about the heat sinks is noted, but the integrated amps were pretty anemic and the sinks could be inside.
I think if you saw the output jack on the e-bay HU without the input plug to the amp in it, it would be different from the one on the OP's HU. But I am willing to say I am not 100% sure, here, by any means, because I have never touched a premium factory setup and it's been ten years since I saw my factory HU.
got a '99 limited with the type 4 double din unit, looking for a sweet hu now, never found and amp in my truck yet...so don't know if there is one, not under seats anywhere i could see with a quick visual inspection. could be wrong not that thorough
hey thanks for getting it right, in a bit i'll know all of this stuff but until then i appreciate the way in which you correct me and in turn also teach me, thanks again ;-)
i think durk was saying with the premium stock unit wont work with out the power amp so he should make sure the stock power amp is installed on his 4runner, i'm gathering that the double din unit or the premuim unit only came with this amp.(stock config) correct?
(not a statement a question if i understood the post or not and if in-fact that is the way it works) 10 points 2 parts.:trophy: lol
