stock replacement springs
MPG4Runner
I've been having a hard time finding stock replacement springs. I don't want to go used as my rear is sagging... I have found 'lifts' but I don't want to lift the vehicle.
what is the best for my setup
stock, running 4 ppl and 3 dogs...
in the end If a lift is best for what I use it for, then a lift it will get. I've heard the OME 2" lift is a 20mm lift (2cm) from stock. I have called several dealers and can't find anything in the 'stock' range. also I'm hesitant of going to the dealership for springs, but if they have them, how much are they?
I'll be replacing both front and rear springs and shocks. would be a good time to replace bushings too.
Thanks for the advice.
H.Sikina
