findlayjeff
while installing my new pioneer deck i cam across that there are two antenna plugs. on all new decks there is only room for the bigger of the two what do you do with the second
Stick Figure said:no adapter that i have seen ... not sure if an adapter would help. The second smaller plug is the secondary antenna (the one in the glass) Toyota factory radios are dual diversity so they can utilize the second antenna, aftermarket radios are not.
The real question should be who listens to the radio anyway? lol
RonMAIDEN said:I listen to sports radio but music is now through my iPod only but an antenna is nice to have if there is a need to use the radio especially on long trips and you need a weather update.
findlayjeff said:i just got the system installed i put amp and sub in, have you guys ever delt with a moaning sound coming from the sub, it sounds like an electrical interference, and the sound changes with the change of the rpm or if you turn the music up you can no loner her it
findlayjeff said:i put it all in, i put the amp under driver seat and the audio takes off from there, so its not on the same side. i have put systems in all my cars and never had this happen
findlayjeff said:the ground is good i went to the seat bolt scraped all the paint off
