Stock transmission + 33" Tires
I'm considering having my A340H transmission rebuild and it's gonna run me about $1600 with transfer case. I wanna put 33" tires or bigger if it don't harm the transmission too bad. What do I have to do to the transmission in order for it to handle safely with heavier tires?
so I did a quick search. Is 4.56 good for at least 33" tires? Also is there a kit I can buy to do it myself?
I have 4.56's with in automatic and 32's on mine. I like it, but i'm soon to be swapping in a 5 speed transmission. You will need master install kit's and ring and pinion set's.
Typically 4.88's are appropriate for 33" tires, but since you have an auto trans, you need to go one step lower, so 5.29's would be the best choice.
Oh, and a gear install is not for the amateur. There are tools and expertise required that most people don't have. At $250 for a set of gears and $100 for the install kit, times 2 cause you have 2 diffs, that's a lot of $ you could potentially waste.
And an aftermarket tranny cooler is a very good investment no matter what.
alright so 5.29 is best for 33" tires just to clear things up. And also im gonna need a lift kit. I was thinking the rough country 5" lift? You guys hear anything about that kit? For about $800 I don't think thats a bad deal...
okay not to sound like a total newb here but I am new to 4x4s and i am confused as to why you need to regear anything to run bigger tires? i have loads of friends that switch tires all the time but i dont remember helping them regear anything. is this something that is only on toyota? (my friends have chevy and fords.)
No, it's not a Toyota thing. On any vehicle if you put taller (or shorter) tires on it throw's the engines operating point out of it's power band. This results in a loss of power, lower mpg, and speedo error.
How much larger a tire you can tolerate before regearing depends on a lot of things, engine size being a major factor. If you have a V8 with a lot of HP the loss isn't as big a deal compared to having a 4 cyl.
How you use your truck also has an effect. If you're a mall wheeler it's not going to matter as much as if you're rock crawling (for example).
okay that makes sense. so it really is up to user perception. the way i was reading into it made it sound like if you didnt regear you would damage the trans.
