Strange clank in front while applying breaks in reverse
wht4thgen912
When I apply my breaks in reverse I get an odd clank/click noise. Has any had a similar issue? 04' v8 roughly 145k.
Any thoughts... Thanks
One side?
Both sides?
Middle?
Could also be loose caliber bolts or worn control arm bushings off the top of my head.
I don't know if it applies to yours but I had a similar noise, click on pass. side & turned out when I added an xtra clip on calipers , noise went away easy fix just sayin !! And REAL cheap
The click sound some are referring to on the brakes, when your pads wear down they start to make this sound around the half way point. Will go away when replaced on that part or as OLJEDI states, you can add a plate if not ready to replace.
The rears do the same also, just doesn't wear as fast.
Jhunt
