s2kpuddydad
My rear window is giving me trouble, it will work with the switch at the center consol but, only if the window is down some already. The switch will work the window all the way down and back up again but, once it is up to a closed possession the switch will not work anymore.
If I use the key in the tail gate the window will go up about another inch more so, the switch is not actually putting the window up all the way either, it is stopping short about an inch.
The key works the window just fine but, the switch will only operate the window if it is down some or, all the way already.
The other thing I noticed is that the door lock light in the dash is not lighting up anymore???
Everything was working fine only a few days ago then....:wtf:
I am not sure if this is a limit switch issue or something else???
