Strange sound after it got cold.
PolevaultT4R
I recently moved up to beautiful South Dakota. My 4runner has been doing great until this past week. Temperatures dropped to around -20 some nights and rarely got above 10 during the day. The other day on start up I noticed a loud whining coming from what sounds like under the hood somewhere behind the driver side. It almost sounds like a power steering pump but the sound increases with speed, not when I turn the wheel. It doesn't rev up with the engine but only as I go faster. After the truck is warmed up the sound seems to go away, although I haven't done extensive driving to confirm how accurate that is. I attached a video which will hopefully help identify the problem. Even with the sound the vehicle seems to handle relatively normal, but like I said I haven't driven for more than 5-10mins at a time and haven't gotten up to any decent speeds where performance would be a bigger factor. Any help will be greatly appreciated.
IMG 1309 - YouTube
That would be your engine belts - it happens to most cars when it's super cold, mine included. I just make sure to warm the car up for about 10 min before driving the beast.
Its your speedometer cable. Throw some lube in that bad boy and the noise should go away.
yep, sounds like a speedo cable.
mine did the same a few years ago. I pulled the cluster, and lubed the cable. its been fine ever since.
youngrk
