Strange swooshing sound ???
srs034runner
I have a weird swooshing sound that sounds like it coming from the center to passenger rear side... Only under acceleration can you hear it, but not on a roll ... So kinda strange... Any ideas???
I have that too. I was going to ask someone else to drive while I go in the back and try and listen. Let me know if you figure it out. There are rubber grommets in the floors with hoses through them near the back. I wonder if none is open a bit.
See that is what is weird to me, I only hear the sound under throttle not while rolling off the the gas ... Very strange... :confused:
Noted. At the drive through window I have also heard a rattling noise. Possibley related. Thanks ks!
I also have a slight rattle at idle, It goes away when you tap the gas, I'll have to check the heat shields and see if that will take care of the problem.
Talyn
