Strange whistle/whirring noise on highway 45-65mph
Big_Cuss
While driving today I noticed a weird steady whistle/whir/hum combo noise that only shows up for 5-10 seconds at a time, that comes and goes every few minutes. It was a solid pitch, so not changing with rpm, load, etc. Wondering wtf it could be?
This is in a 2018 TRD Off Road with stock KDSS suspension.
When I first heard it a few weeks ago, I thought it was those inner fender plastic aprons catching crosswinds, but more recently I've heard the noise even without strong crosswinds.
Anyone else have this or know the cause?
Update: The noise only starts to happen occasionally at 50-65mph. Like a light steady whistling or whirring -- and it stops the second I touch the brake pedal.
Bad wheel bearing? Brake disc touching the pad slightly somehow?
I get something similar but at higher speed, a high pitched noise. Sounds like brake noise, but I don't get it at low speeds/when braking. It's intermittent, or else I keep my radio up too loud most of the time. Interested in seeing what you find out.
Possibility is that it's your aero bumps on the side mirror, this happens to me once in a while with the right conditions of speed and natural wind. Constant high pitched sound until I break or turn a different direction into/out of the wind etc
That's exactly the issue I have. So weird. I wouldn't think braking would change it.. but then again, it would change the pitch, airflow just a tad.
Jhunt
