stronger accel harsher vibrations, rear drive shaft already rebuilt.
kingin
I'm trying to figure out what is the next step in finding a vibration that gets stronger depending on how hard I press the gas pedal in any gear or speed. Vibration seems to be coming from front right side, at lower rpms 1-2k cruising I can feel a slight vibration in pedal that comes and goes in sequence.
If vehicle is in neutral and rev to 3k+ I do feel a slight exhaust vibration.
Had rear drive shaft redone balanced and cardon joint replaced including rear u joint. Now I'm thinking trans mount or motor mount? Front wheel bearing?
1999 4runner 3.4 5spd 185k
Thanks in advance
I figured it out I forgot to add grease in slip yoke after lift, rides a lot better now, hope I didn't mess anything up in diff. Lol
Are you getting vibrations in the steering wheel or in the seat? Vibrations in the steering are a sign of something in the front, and vibrations in the seat are a sign of something in the rear. How old are your lower ball joints on the front, tre's, and so forth?
My 4runner is vibrating between 70-78 miles an hour and emitting a very loud and deep noise the vibrates your brain. u joints are tight and have no play. what else could it be?
vibration
Do you feel the vibration in the steering wheel or 4runner floor/seats?
Steering wheel = bad wheel balance
Floor/seats = more than likely bad drive shaft. Can also be rear wheels but this is not too powerful to shake the whole runner
charlesz
