Strut Recommendations
Carl1975
I have a Daystar leveling kit that I plan to install. I am also changing the CV joints, wheel hub and new slotted/drilled rotors. My OEM struts aren't bad but at 130k miles it's probably time to replace them. Any recommendations on struts with a 2.5" Daystar lift?
Bilstein 4600 series if you keep the spacer. I would recommend the 5100 series and ditch the spacer, You will keep all of your up travel and get the Bilstein ride. Good luck.
BillM777
