Stuck in Mud, New tractor sound.
CanukRunner
I finally got dirty for the first time with the runner this weekend..
Got stuck i a mud hole up to me headlights...lol
After rocking and a tow my truck started to sound a little bit like a tractor under load. I also noticed my transfer case is starting to leak from the center....hope thats not bad...lol
It doesn't look like the pipe got hit but I think the revs might have cause a manifold leak..
Has anybody put on headers? will they screw up anything?
I found this old listing... TRD would be nice but they are expensive....
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=180497946576
For your sake, I hope it's a manifold leak. The only other thing that makes it sound like a diesel is a spun bearing. :(
That said, exhaust manifold or header install on these 3.4's is actually a PITA. Which is sad, but that's how it is.
spun bearing? Which one?
I am pretty sure its exhaust.. I've heard manifold leaks before... sounds like a chugging tractor... not hearing any mechanical hitting noises.
Rod bearing would be the most likely if it was a bearing. Getting a little water into the engine, and then into the oil...that's a good way to spin bearings. Which is why I mentioned it...since you were stuck in it pretty deep by the sounds of things.
I couldn't tell if you were describing it as a "clatter" or a "chug". You're the one listening to it, so if you think exhaust, then that's where to start.
