Suggested mounting locations?
wkparker
I'm getting ready to install an OmniFi MP3 player in my new '05 SR5. The display for this deice is a DIN-sized unit that controls the functions and displays title/track/ID3 info, etc.
I want to keep the install as "stealth" as possible, so I'm looking for a mounting location for the display that keeps it easily accessible but hidden when I don't need it. I'm thinking of mounting it inside the storage compartment under the HVAC controls, but this will take a little surgery to make it fit.
Has anyone mounted something similar in their rig? Any suggestions appreciated!
Very nice! Reading the thread, it sounds like you cut a hole in the armrest for the unit to show through, correct? The OmniFi has a faceplate that is mounted separately from the hard drive, but I might be able to squeeze it into the same spot and rout the wires under the armrest. Do you find that position hard to see while driving?
Awesome install.
How did you get the display "TOYOTA"?
Is that an MP3/CD player or a hard drive MP3 player? If so to the latter, how big is the memory?
Yeah, I cut a whole out in the armrest using a dremel. It's not that easy to see while driving. You obviously have to take your eyes off the road for a second, but if you glance down you can see it fine.
The mp3 player is an "empeg" 20GB hard drive based player. I bought one before they stopped making them a couple years ago. It runs on linux so it's totally customizable (that's how I got the TOYOTA bootup logo to show up) and uses normal laptop hard drives for storage. It's really cool, I wish they still made them.
Thanks. I tested the OmniFi display in that location, but it's a bit too wide - I would have to cut away the raised ridges on the side, which is a little more agressive than I want to get. I also tested the space above the map lights and the sunglass holder, but I think the console storage spot is going to work best. I'll have to cut a hole in the back of it and trim the back of the panel, but it will be hidden when the panel is closed. Weekend fun!
