Sunroof Leak Repair
Steve8v92
I just noticed that my sunroof is leaking or seeping, either way, it does drip a tiny bit,
Does anyone know of a good way to reseal the sunroof or is it better left to professionals?
I'm having the same problem on my '99 T4R. The leak is in the center front of the sunroof. It leaks when there's heavy rain or in a "touchless" carwash. The dealer said it's probably a leaky weather strip that surrounds the glass. He said it's about a 2 hour repair for which the charge would be about $164 + the part. His suggestion was to endure the leak (harmless, he maintains) until the spring. This would let it dry out AND, with warmer weather, allow the existing weather stripping to become softer and more pliable. He was really hinting (as much as a dealer service manager is able) that I do this myself. The main thing he said was to get the old stripping off clean.
also check your drain tube it is prob clogged ..... roll window back look in pas side corner in the track see the hole? bet its got junk in it!
