I have on 01 with a sunroof. The sunroof mechanically works fine by all measures except for the resting or stop position when you close it. If you slide it fully open toward the rear of the vehicle - it works fine. But when you go to close it, it will stop or rest with the rear of the glass slightly open. The same thing if you tilt it open - works fine. Hold the button to close it, it stops short of being fully closed. I can tap the button and position it where I want. But after reading all of the SR issues, I think I should get this fixed. Is there a way to reset or establish the start/stop position of the sunroof?
