Sunroof Switch
natevans65
Hi....on my 04 Sport, the sunroof switch DOES work but I have to manually hold it in order for it to get properly seated. Has anyone else experienced this and if so, did you have to replace the switch module or is it somewhere else in the roof or truck??? Thanks!!
Have you disconnected your battery lately? Try opening the sunroof all of the way and then while closing it, keep holding the close button until 5+ seconds after it closes all of the way and then goes into the vent mode.
1) Open sunroof
2) Close sunroof while keeping the close button pressed
3) Watch sunroof close/go through all of the way closed to popped open to vent
4) Wait 5+ seconds
5) Release close button
I'm not sure if this is exactly what you were asking, but thought it would be worth a try
Ya know.....I have had this truck since day 1 and I never new what was going on with the windows, and yes....it was usually after having the battery cable disconnected. Gonna go try it now!
PROBLEM SOLVED!!! You guys rock! Thank you.....I am sure the steelership might have sold me a new switch. Did exactly like you noted and it works perfectly.....thank you much!!
