Suspension Question...
greenhouse507
i recently lifted my car 1.5 inches, purchased new tbars ,damper, shocks and coil springs...i am plannin on getting some bjspacers and 1 inch coil spring spacer...what i want to know is whats the highest sombedy at the forum has cranked the tbars...because i am planing on crankin a litle bit more the tbars (currently tbars lifted 1.5 inches)
please let me know the highest you have cracked the tbars...thnks:hungry:
You've got to look how much space is left to the bumpstops. (with IFS the tbars can go about 2" higher than stock; then you are on the edge...)
ok so with 2 inches i should be fine then? thnx for the info!!
my kit is moslty ironman and toughdog panhard....
Not necessarily. Your ride is going to suffer, you'll loose suspension down travel, and the increased angle on the half shafts can be hard on the CV joints and boots. But you can always adjust them back down.
even if i add the bjspacers ? right now my front is lifted by ironman t bars ...and to be honest the ride is not to stiff thats why i am asking if i add the 1 inch coil spring spacer in the back and add the bjs pacers on the front and lift the front a bit more with the t bars do you think i will be harming my suspension ??
the reason why i need the extra inch is because when i am off road my 33´s sometimes hit the frame...so i have 2 options 1. do a 1 inch bodylift 2. why i just mentioned at the beginning...thnx for the assitance!
OK, go with the BJ spacers, and since you're happy with the ride as it is now, crank the t-bars a bit more and see how it goes.
