Jeff16758
OK,
So at the direction of my fearless navigator in a new offroad spot I ended up up to my doors in mud/water/ice last night. The exhaust went under, but I don't think I pulled in any water in the intake (initially). The water was just below the top of my front right tire. I have a 3" lift and 33's, so I'm thinking i never put my intake under. While trying to get out my temp was fine and everything was running normally so I didn't want to shut off my engine even though I knew I was stuck due to the exhaust being under. Eventually my engine compartment started steaming pretty good (from the water around it I believe) and eventually my check engine light came on and my engine coughed, so I immmediately shut it down.
Long story short we got it out and it's in my driveway. I never tried to start it again once I shut it off. I took the airbox and intake apart and didn't find any water other than a tiny sheen on the bottom of the airbox and the bottom 1/2" of the filter dirty. I replaced the air filter, cleaned the MAF and removed the plugs and turned the engine over a few times with a little bit of mystery oil just for piece of mind. Same thing, no water and it turned over fine. I replaced the battery (needed it anyway), the plugs and wires. Put a new air filter in and made sure everything was dry. The codes have cleared (I have a good diagnostic tool). It turns over fine but will not run. I tried starting it without the EFI fuse in to make sure it was clear of everything and not flooded.
So basically now I'm out of ideas. I'm wondering if someone else out there had the same problem and found a trick (a blown fuse that doesn't throw a code, another place to drain, etc....).
PLEASE let me know if you have a similar experience or a suggestion. This is my daily driver.
Thanks in advance.
Thanks in advance.
