Sway-Bar End Link Bushings
BobLMTDT4R
I just replaced my front sway bar bushing, wow what an improvement. Now I want to replace the rear bushings and front and rear swaybar disconnect bushing but am having a hard time finding them as a kit. Can anyone help me out here? Pepboys and Autozone said they are special order. I would like to get the urethane bushing is possible.
Bob
1997 Toyota 4Runner Limited
3.4L, Auto, 4x4
What gains do you get from this mod? Just non squeaky bushing? It looks very cool and probly not a bad idea to do it. I was just wondering. Thanks
bushings
You should be able to go to your local automotive store and buy urethane bushings there for the links themselves. When installing urethane bushings bushings make sure to apply a generous amount of water proof marine grease. or you will start hating your drive do to the binding noise of urethane. also this mod won't do that much unless you have the Addco sway bars. I would suggest waiting and doing it all at once and defiantly get the greaseable bushings!!!! Also sense I don't do that mush off roading I bought the Addco sway bars these are much thicker than stock and make a huge difference in cornering. near flat around corners. I will post a link to what you will need for this kit because addco send you the bars but there are many other small things you need to do to maximise your gains!! I must say that between these two mods my 4Runner drives and handles amazing!!! also make sure you buy new factory links. man things add up fast. but well worth it
http://www.top4runners.com/ja/addco.html;):
