Thought maybe it was because my front skid took some hits and is dented in, but notice loud pop when swaybar moves but also popping when turning sharply. With 3" lift is there binding issues or just swaybar hitting the skid? Have 3" lift springs and Blistein shocks.
I think the best fix is Shrockworks skids. Then you don't have to worry about it plus the added protection is great peace of mind.
The BudBuilts are good to put you need to space those out too so you wont have a flat belly. Hence the reason I went with the Shrockworks.
But the cheaper fix is six spacers for those pesky brakets.
No need to buy expensive skids to solve the problem. You'll need to space the two support brackets as shown. IIRC they were just 1/4" thick washers. Mine came with the swaybar relocate kit that was included with the front c/o's but i'm sure you can get some thick washers from the local hardware store. Good luck!
she has the Budbuilt front skid, but its contacting the brackets.
That is the problem with the Bud's, they still need those brakets. So if you use a sway bar with the relocates you got to use spacers on the brakets and there fore spacing the skid out too.
Good luck with the problem.
:vader:
Does anyone know the exact washer number for the radiator drop? Or is it just one of those guess and test things?
1/4 wasn't enough to clear mine so I went with 1/2. Worked perfect.
See above. It's the swaybar contacting the radiator support brackets, space them as shown and you'll be good to go. :boink:
