Sway bar repair and link replacement
Nelsonmd
Hey all,
So one of my front sway bar links has rusted and broken, and the sway bar is just hanging on the passenger side. So I need to replace the links and bushings, and the sway bar bushings. My question is, I don't really want to pay the $65 each for OEM links from a toyota distributor, what are other good brands? The one's I have found so far are:
NAPA Chassis
Master ride Chassis (both from NAPA)
Duralast
QSTEN
Sankei
Mevotech
Moog
Replacement
Any comment on quality compared to OEM?
I got mine from Advance Auto for something like $23 for one. It was just as beefy, (which is not very beefy) but not as stiff at the joint. I figured for 1/3 the cost, why not. Perfect fit. I looked at NAPA--normally my first choice on aftermarket--but on-line I couldn't find one that looked right.
In fact, I found a lot of listings that just did not have the same geometry as OEM. I recommend you pull the old one (if you didn't already) and have it at hand as you try to replace it.
Mine busted today.... ironically right after being in the shop for brake work. I'm convinced the shop messed something up, but I can see no reason for them to have touched the sway bar link.
If I can't talk the shop into fixing it for free, I'll be looking for a repair kit. Probably grab whatever is available from Advanced or Pep Boys. Kits are cheap.
