Switch interior lights to LED?
Very easy, go on vleds.com to order the bulbs then it is a simple as taking off the covers and swapping out the bulbs.
They look great.
i know ive said it before, but running a wire from the dome to mounted footwell lights is really super easy & a great very useful mod. & they will come on with the door lights. u can even just get the stick on light strips, it cant get any easier, & imo, is just as good or better than the map light mod since it puts the light right where its needed. just my 2c.
I'm sorry chaz...mounted footwell light? Are you talking about some after market light you mount in the footwell area?
JA has a write up on it. its a little more work than what i did. after talking to jason burtman, i found out all u have to do is run a wire from the front dome under the headliner, down the door trim, to under the dash, & just connect 2 stick on lights. works real well.use a wire snake or hanger & just stick on lower dash panel.
005-2.jpg~original
