WHORERUNNER
Thinking about doing a whole tranny flush as maintenance. Was considering syn atf. I have a 99 with 110k. Any experience, I was thinking about amsoil.
I've been using Redline D4 ATF since new.
I replace the fluids with D4 ATF at 10k and immediately notice the smoothing shifting. I have Redline products in my BMWs and you can tell the improvements in shifting expecially during winter cold months.
I'm a firm believer in Redline products now.
As for draining, ever try the MityVac products? I've used this product for most of my transmission and oil extraction and love it. In fact I've read that even the Mercedes Benz stealer now use this product to change their oils when cars come in for service. Simply stick the tube down the dipstick, give it a few pump and out comes all the oil.
Amazon.com: Mityvac 7201 Fluid Evacuator Plus: Automotive
How can that get ATF out of the transfer case?
You can actually get 13 qts of ATF out of your trans with that or does it just empty the pan of the usual drain of about 3qts?
The Transfer Case does not Use ATF!!! it uses Gear Oil!!!! do not mix the 2. unless you want a disasterous result.
Transfer case gets drained and filled just like your front and rear differential. And it uses the same fluid: 75w90 gear oil. No ATF....like Hilux said...that would be very bad. For reference, most people run 75w90 in the rear diff too, even though the factory calls for 80w90. That way you can just get a bunch of 75w90 and use it all three places.
Yes, please refer to this link for Transmission flushing, changing fluid etc. Im my experience, if you just pull the drain plug on the transmission pan and let it drain with the truck flat on the ground, you'll get about 3 qts out. If you jack the front of the truck up, you'll get 4 qts. If you jack the front up AND let it sit overnight, you'll get like 4.3 qts out.
No matter how you do it, it's only a small percentage of the total ATF in the system. The write-up listed above is the only way to do a total fluid change, because the torque converter holds so much.
For the OP's original question. I use Valvoline Maxlife ATF and love it. It's a semi-synthetic fluid with a good additive package. And it's pretty cheap. 4qt jug at my local Walmart is only $17. I've used it for the last 25k miles, and it's been great. I'm actually going to have it analyzed by Blackstone next month when I do a drain/refill of the pan.
Did your shifting improve, mine is fine just want to start and put some good synthetics in the drivetrain.
