Synthetic Oil Change - How Often??
thomasugenius
So, I know my first problem is that i don't drive my 4Runner often enough...I put 6000 miles on it a year. I run Mobil 1 Synthetic and am unsure if I should change the oil every 6 months or every year? Normally, I would change the oil with Mobil 1 very 6000 miles, but TIME is the question here? Not Distance.
Thanks!
I would do it every 3k - or every six months in your case - just to have peace of mind. After all, six quarts of Mobil-1 will run you only about $25 or so.
$50 worth of oil for an entire year is a mere pittance for a vehicle that costs almost thirty grand!
I change my oil every 3k to 4k in my 4Runner and always use synthetic oil (Mobil-1). I also change the filter (Toyota OEM) each time.
Dont know how old this thread is...but
Used Oil Anaylsis will tell you how long you can run oil for..instead of guessing.
In my old Isuzu Trooper, I gave it a fill of Mobil 1. Added a quart every 3000 miles or so, and changed the filter once a year. A yearly used oil analysis always showed the oil was still good, and I ran that truck to 90,000 miles with no engine problems.
Was that a good idea had I wanted to keep it until 200,000 miles? Maybe so, maybe not.
I can't do that with my T4R, because it simply does not seem to burn oil, so no opportunity to replenish the additives with a fresh quart!
I think time is more of a big deal if you don't rack up 20k a year on your vehicle. I run M1 syn and I change it about 8-9k miles which works out to about every 10 months which is about as long as I like to go.
OK. In that case I'm safe at changinig it every 6 months and could probably go for 9 months or so total time to conserve without increasing wear. Thanks
