Synthetic or conventional oil?
i've initially grabbed a 5 qt. jug of Super Tech full synthetic at Walmart. I think it was about $15. This site link gives Super Tech a green light, so I guess it is a good choice option. Still haven't decided to go synthetic or not.
Quite a bit. PQIA conducts independent testing of motor oils and reports their findings here:
http://pqiamerica.com/PCMO_Sample_Summary_12_15_2016.html
Don't let the URL page name throw you off, it includes all 2018 test data. You'll see quite a few store brands that failed to meet API specifications, and you'll see wide variation in characteristics that reflect quality such as Total Base Number and additive concentrations.
For the 4Runner, I use a good quality, name brand, conventional oil and a Toyota filter, every 5k. I don't burn a drop, it's not overly-dark when I drain it, and at 200k miles, I think it's doing the job well.
I use full synthetic in my Miata because it's the factory fill, only gets changed once a year, and sits quite a lot. I used the SuperTech from Walmart this year as it tests well and I thought I might do an extra change this year. but usually it's Mobil 1.
There is only one entry for Toyota oil and it’s the conventional 5W30 tested in 2012. They don’t have data for the newer Toyota 0W20 (like for 5th gens).
They seem to put more effort into testing off-brand crap oils to dissuade the public from using them.
Get on the mobil1 rebate. You can even stack with other discounts.
Ex: 6 quarts at costco for $38 - $10 (costco sale) - $12 (mobil1 rebate) = $16.
Stock up when there are sales, then you hardly have a reason not to run top notch, full synthetic motor oil.
I bought mobile one from Costco on sale for $ 10.00 off = $27.69 but when I went to Mobile One's website you have to buy the oil from participating retailers and Costco is not listed as being one.
You can still submit it. It's the same for Walmart. Never had a problem with M1 accepting it.
I change my own oil, it's not worth driving to have it done and I've had far too many drain plugs messed up by service shops, includin dealers.
I used to run mobil 1 but was unhappy when they lost the LLO1 certification required for BMW. This caused me to start researching quite a bit. M1 has become the low end of synth oil, not worth buying imo. I will admit that the quart bottles make fantastic funnels for oil filling.
At this point I'm a fan of castrol edge or even the magnatec full synthetics. I buy 5 quart jugs as I can easily recycle used oil in them and amazon ships them.
Final point here - Synthetic oil lasts longer. It breaks down at a much slower rate than regular. An engine with proper syth oil changes looks amazing inside. It provides improved tolerance in the case that you've had extreme heat or cold and will often keep surfaces coated a bit better. If you happen to go 1k over on your change interval with synthetics, you'll be better off than doing the same with conventional. The idea that 'toys run clean so you don't need synthetic' is a bit myopic. Yes synth will ash at a higher temp than conventional, but there are many more benefits than just the higher flash point!
My 4runner V6 has always run on conventional oil. It has 200k miles on it. Synthetics have come way down in price. I'm wondering if i should make the switch to high mileage synthetic.
Stick with conventional.
I switched my V6 2005 4runner from conventional to synthetic and got "leaks" and drips until I switched back and the drips stopped.
See Scotty Kilmer video. 50 years a mechanic. 1 billion Youtube views.
"Wouldn't change to synthetic". - scotty kilmer synthetics in old cars - Bing video
[MENTION=279139]Captsolo[/MENTION]
Gone on to reviving 2 year old threads huh.
You forgot to mention your guru’s videos.
I just switched my 07 4runner to mobil1 and added a bottle of AT205 to the oil. It softens the seals to stop leaks. My engine has no leaks presently, so time will tell
reviving 2 year old threads with this nonsense again...
you forgot to mention the head gasket issues synthetic oil will cause because it's "super slick"!! & dont forget to tell everyone how you use 10/40 in an engine that calls for 5/30! LOL!
Get lost. You are a mental case. Who cares?
IGots over two million in assets and cash and vet connections that pay monthly and daughter with 3.3gpa from Florida State and $60,000 job at biggest stock broker in the world.
Can’t complain.
I didn’t want to add that AT 205 although SK swears by the stuff. There has never been a single additive to my V6 4.0.
Going back to conventional and the oil drips are down to 1 drip a week, and the garage is clean. The synthetic didn’t work in my 2005 4runner. :drum:
When you lose an engine because of that cheap synthetic, good luck getting Mobil 1 to reimburse you.
Stuff makes an older engine too loud and clunky sounding compared to conventional. Way overrated. Rip off!
Ask SK yourself. 50 years' experience as a mechanic. Grandfather owned a gas station.
What do you own triethylborane?
Do your own research.
Scotty Kilmer synthetic V conventional: scotty kilmer synthetics in old cars - Bing video
Which car brands are best according to mechanic Scotty Kilmer? Which car brands are best according to mechanic Scotty Kilmer? | Wanderings
MORE PROOF: New Toyota Car Losing Oil - Lighter Weight Oil to Blame New Toyota Car Losing Oil - Lighter Weight Oil to Blame | Toyota Parts Center
2006 4runner Oil Leak After Synthetic
2006 4runner Oil Leak After Synthetic | Bob Is The Oil Guy
triethylborane YOU WANT ENGINE DAMAGE? Read this:
Older cars usually have to use conventional motor oil instead of synthetic motor oil. Switching to synthetic can cause engine leaks or engine damage. What Are the Risks of Switching to Synthetic Oil in Older Cars? | YourMechanic Advice
Going back to conventional and the oil drips are down to 1 drip a week, and the garage is clean. The synthetic didn’t workin my 2005 4runner. :drum:
Stuff makes an older engine too load and clunky sounding compared to conventional. Way over rated. Rip off!
Ask SK yourself. 50 years experience as mechanic. Grandfather owned a gas station.
Again, empirical evidence and going to Kilmer. I bet that Kilmer would go for synthetic in the 1GR, or pretty much any automotive engine this side of 1950 AD (piston engine aircraft engines are a different story for leaded fuel reasons).
Are you a troll, a bot or just baked out of your mind? :hippie:
so now its 1 drop a week?? i thought it stopped completely & the leak was all synthetic oil's fault? even with the 10w40 conv oil you use you still have a leak!!! WOW! how about finding the cause of the leak & not blaming the oil? hmmm...
& now you think using synthetic will make you "lose an engine" because of that cheap synthetic oil?? not just head gaskets but losing engines will happen due to using synthetic oil? your delusions get worse & worse with every post you make! you must enjoy having people laugh AT you & not WITH you! :lmao:
Can you read?
Tx470
