michael90630
I just changed all the gear oils of front and rear differentials and transfer case in my 2007 V6 4WD T4R. The oil capacities of each are available in the User Manual and PDF Repair Manuals and for both front and rear diff. the amount was correct.
However, when I opened up the fill-plug of the Transfer case, a lot of oil started pouring out. My vehicle was on a level/flat surface. This did not happen for either the front or rear diffs. I have purchased this vehicle less than a year ago and all these fluids are factory-filled. Almost a cup of used T-case gear-oil came out. The oil capacity is 1.5 U.S. quarts and that's exactly the amount I poured in when it started to seep out - which typically should be the correct level. I drove a few miles in 4WD mode to get the gear-oils a little bit hot before beginning this service.
Is this normal? Did anyone experience T-case gear-oil coming out of the fill-plug? Why would Toyota over-fill the T-case from the factory? I did not try to match the total amount that came out - (maybe I could have if I had tilted the vehicle on the back with some jack-stands) and therefore pumped in exactly (1.5 quarts).
Any ideas?
Any ideas?
