Now that I have the weak horn issue resolved, thanks to the excellent help from this forum, I need some info on the brakes of my wife’s 2010 4R.
I have had the chance to finally put some miles on the vehicle and I find the brake pedal “feel” to be a bit unnerving. She previously had a 3rd and 4th gen 4R's and when you pressed the brake pedal you instantly got a reaction from the brakes—press pedal, brakes applied, truck starts to slow.
With the 2010 it is—press pedal, press pedal some more, then get brakes applied, truck starts to slow. Also, once I’m at a complete stop, it takes what I consider to be a heavy foot on the pedal to keep the 4R at a standstill. If the AC happens to kick in then I need even more pedal to stay at a standstill. I have nearly crept into the back of multiple vehicles due to this.
One thing that will overcome this is to “double pump” the pedal. If I do this then the pedal “feel” firms up and I get—press pedal, brakes applied, truck starts to slow. Same thing at a standstill—a quick partial release and press of the pedal and the mushiness is gone and no more creep.
Dealer says the new electric-over-hydraulic brake system on the 2010 is responsible for this behavior and it is working as designed. BTW, this has been happening since day one.
Since my ’09 Tacoma does not exhibit this same behavior—at least as long as the rear drums are adjusted properly—it is a bit disconcerting to jump into the 4R and have to deal with this.
Any thoughts? Anyone else having this issue? Thanks.
