T4Runner 2003 LE without GPS navigation system
cafebabe
Hi guys,
I have T4Runner 2003 LE without GPS navigation system and
I want to buy that navigation system that can be used with my 4 runner. can someone point me where I can buy that system, thanks.
-cafebabe
If you check out partznet.com, do a search for your truck, then the navigation system is located in the electrical section, there are two components, the display unit ($482.79) and the module. ($3557). You can probably get a cheaper aftermarket system. That site is probably the cheapest you will find for Toyota OEM Parts. Good luck
Check out the link that Bobby posted above. Brand new Toyota navigation systems at a much cheaper price.
what unit will work for 2003 4Runner LE
Thankx for everyone for reply my post, I've checked that oemvalue.com site and they have 2005 Camry Navigation Unit and I don't understand that this unit will work in my 2003 4Runner or not, does anyone knows about that.
I do not have JBL in my 4runner and they have Three Packages To Choose From, does this means that I should choose package #1 (http://www.oemvalue.com/request/toyotanav.htm) ?
I am really confused here:confused:
Thanks for your help
-cafebabe
Re: what unit will work for 2003 4Runner LE
-cafebabe
Yes, that's correct. If you don't have the JBL sound system, then the Camry navigation system will work.
Hi Hitman,
Thanks for reply, just want to clarify one more issue:
I've checked this thread(http://www.toyota-4runner.org/showt...&highlight=GPS navigation system&pagenumber=3) and according to this, camry navigation system will not work in 4runner with the already equipped
10 speaker JBL sound system so use Solara Navigation system instead.
my question is that my 2003 4Runner doesn't have 10 speaker JBL sound system so
does it mean that camry navigation system will work 2003 4Runner?
I am getting confuse again, hey thanks for your help.
-cafebabe
cafebabe said:
Hi Hitman,
-cafebabe
If you have the standard stereo (not the JBL 10 speaker system) in your 4Runner, then the Camry navigation system will work.
4Runners that have the JBL stereo need the Solara navigation system.
Great info! I have a 2003 SR5 without the nav system. I also have a lead on a nav system from a 2003 limited. Is this a 'plug-and-play' switch if I want navigation in my SR5? I found a head unit, but after reading this thread- do I need to locate a module as well? Thanks for your help!
No it is not a plug-n-play swap. YES, you will need more than just the head unit.
The 2003 nav display had a separate nav unit which gets mounted in back. So not only would you need the head unit, you would need the nav unit. THEN you would need to get the JBL amp, the JBL speakers, the JBL sub and sub box, the correct rear trim piece for the navigation unit and subwoofer, and all the interconnecting wiring and connectors.
GO AFTERMARKET. You will have much less heartache. The OEM definitely is not worth it.
EDIT: Ok, I shouldn't say it's not worth it. The units are very nice over-all. However, aftermarket units offer so much more without as much effort to ensure proper function, and normally for less money.
Member Lax745 has an OEM unit which would be a plug & play, but you would have to add a few things still (gps antenna, etc), but it's OEM if that's the look you are going for. http://www.toyota-4runner.org/sale-t4r-items/191222-fs-4th-gen-oem-toyota-navigation-gps-system-%24600-obo-maryland.html
One other thing which may be an issue, but I doubt it in your case, is the center instrument trim.
Toyota felt it was necessary to make two different trim pieces dependent on the radio that is installed. I think you will be ok though. When I had "gotta have the OEM navigation unit" bug years ago, I actually bought the trim piece for $300. Oh yeah, then I had to find a climate control unit too - because, of course, that's different too. That I lucked out on and found one fairly cheap. In the end, I removed all the JBL and went aftermarket.
