Tacoma body lift
wrestler157
Does anyone know if a 05-09 tacoma body lift will work with a 4gen? My buddy has one he is going to give me but im not to sure if it will work being they have 12 blocks and 4runner uses 6.
It should be roughly the same body mounts, they would most likely just be in different spots on the frame compared to the 4Runner, but that won't matter for a body lift. The only issue I would see with the body mounts is that the Tacoma may have a different number of different diameter body mounts which would require different pucks. But I haven't really made a comparision between the two. Just make sure you match up the OEM pucks with the new ones so you don't end up putting too much stress on a body mount. :)
Just so happened to have a '08 4Runner and a '12 Tacoma laying about, they look to be the same radiator with the same mounting points. I would assume since the T120 platform covers the FJ, Tacoma, LandCruiser Prado, GX470/460, and 4Runners that the steering will be similar if not the same, much as how the suspension components are similar in mouting points and over all design.
