Tacoma fog light switch help.
ply2win
Member
So I recently purchased a factory Tacoma fog light switch to replace my on board air Toyota style push button switch. They both are 4 prong plugs but I can not get the Tacoma one to work. Any help would be greatly appreciated. I've combed over this forum, toyota120 and tacomaworld and can't find a solution. I'm using it for my led light bar and I am using a relay.
Are you not understanding the picture of how to wire it or is it wired correctly, but not turning on the light?
If option 2, I would check all your connections again and/or disconnect the button from the harness and check the connectivity across pin 3 to pin 4 to make sure it's closing the circuit correctly.
Step 2 would be to check the relay wiring.
Let us know if it's option 1 instead - that can get wordy on the explanation.
