Tacoma suspension question
Picked up front springs and shocks and rear shocks from a 2020 TRD off road Tacoma today. Ordered new top hats and the bushings for the rear. My question is will I need a spacer in the back to make it look right and how much lift will those springs give my '05 V8.
Sent from my SM-G991U using Tapatalk
Yes those are the ones that I got for the rears and I got KYB top pieces for the front struts off Amazon. So with the added lift in the front the rear will still look ok?
Should be fine. I used new 2007 FJ coils in the rear of mine when I replaced the XREAS. Had a slight stick bug stance but still looked fine. Easy enough to add small spacers later if you need to.
No top hat needed either. I did this mod to my ‘06. Tore out the XREAS, did the rear bushing and installed. About 2” of lift (my xreas was trashed) and looks great with 265/70r17 tires.
No top mount needed? When I got mine they were loose coils on the front struts
Previous owner reused the top hats so that's why I purchased new. Wish they would have been together to save me the spring compression but local deals are hard to find.
Ambrose67
